Can you add the quantity of an item to a note or something in a drawing?
Hello,
I'm trying to automatically insert the quantity of an item into my drawing but don’t want to use the entire BOM table. I want to make it easy to see, like a big X with the quantity.
I could type it manually, as my assembly is fairly small, but I’d like to avoid as many human errors as possible. I see you can add a bunch of parametric stuff, but I can't find the quantity.
  • martin_kopplow
    You could make a reduced BOM table that only holds the part name and the quantity.
    I've had a lengthy discussion in the company about how useful it is to have the quantity printed on a drawing. My position is that it is none of a parts business to know how many of it exist elsewhere. Sure, the shop wants to know how many they need to produce, store or pack for any given project. But that is what BOMs are for. The same part might be used for different assemblies or even projects, and what quantity for which project will there be on the part drawing, then? If you change the design and add say one more bracket, you'll have to update all bracket drawings issued before, make a new revision for already relesed parts, and hunt down all older copies of it flying around the shop floor, for they communicate the wrong quantity. Been there. I learned it creates more errors than it prevents.
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,930 PRO
    Try using a callout instead of a note
  • martin_kopplow
  • eric_pesty
  • Dessinateur_Soudure_LL
    Dessinateur_Soudure_LL Member Posts: 6 ✭
    Thank you Eric_Pesty.
    That's exactly what I was searching.
  • Julian_Rios
    Julian_Rios Member Posts: 2 ✭
    Hi @martin_kopplow, how do you suggest to make that reduced BOM table? I need to automatically display quantities on a specific view/detail of the drawing.
  • martin_kopplow
    Hi @Julian_Rios ,
    You could create a new BOM template that has only say two columns, say part name and quantity. Whenever you insert a BOM table, you could choose that template as the BOM's format. BOM tables in different format can exist in parallel in a drawing sheet or in a set of drawing sheets. That way, you could place a minimalist BOM table near the view in question.
