Would like to keep the blue part within the gray walls, not sure how to go about this.
maxime_veilleux909
Member Posts: 3 PRO
To get the blue part within the grey walls will depend on how you created the blue part. Please share a link to your document and make the document copy-able. Most likely you just need to sketch and extrude the blue part after the grey part has been made. This way you can constrain your sketch to the grey walls.
The forum is fantastic, but don't forget to check out the Onshape Learning Pathways if your interested in learning how to Onshape better.
▚▞▚▞▚▞▚▞▚1
