How can I prevent loft twisting, even in a very simple case?
frank_paynter
frank_paynter Member Posts: 34 ✭✭
I have a small public document with just two sketches, and I am trying to accomplish a non-twisted loft between them.
Loft Matching | Part Studio 1 (onshape.com)
I have made sure both the circle and the oval have the same number of points, but when I try to use the 'Connections' feature to define the connections between the oval sketch and the circle sketch, the loft stops generating. Only when I remove all the connections will the loft come back (twisted, of course).
This seems like it should be so simple, but I'm unable to get it to work. Can anyone tell me what I am missing here?
TIA,
Frank
  • GregBrown
    GregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 407 image
    edited August 2024
    It works really well with a single connection defined, perhaps you missed a pick in defining the connection?
    Here it is, note I've turned on the Show isocurves which is always a good idea when evaluating connection issues
    Check this out…
