Skew a part
johan_nilsson050
Member Posts: 4 ✭
Hi,
I making a part that needs to lean as you can see in the picture below. If I make the complete part with then pins and everything "straight up" first, is there a easy way to make it lean like in the picture?
Matt_Shields
Member, Onshape Employees Posts: 930 PRO
@johan_nilsson050 , the selection for Extrude direction should be a straight line angled the direction you want the part to lean.
Not that I know of, but I know you can add a direction to a solid extrude. Then you could shell.
I'm thinking "sweep" - one sketch to define profile, another to define path.
Don't know what I'm doing wrong but it will not lean… when I try direction?
Johan here are two ways to model the same part (profile shape is not the same, but methodology still works).
https://cad.onshape.com/documents/838080024189976c39bb6844/w/b95892f2d5968bd72a12cf53/e/6c06b80a59a9cf6642c71c00
Look at the two different configurations(top of feature tree), use the roll back bar to look at the feature progression. Same end result, using two
different methods.
