Measurement popup not showing
@herb_langer ,Sometimes it happened due to internet connection speed which may be slow at that moment of time when you are measuring. The Onshape measure tool is available in Part Studios, for sketches and parts, and in Assemblies for parts and assemblies; it appears in the bottom right corner of the interface when a selection is made:
The measure tool displays measurements dynamically whenever you select entities.
1) Select any entity. The measure tool show measurements for that entity.
2) Select another entity. The measure tool shows measurements between the entities.
Note the triangle on the measure tool. Clicking it shows more measurements.
You can use the information displayed to enter values elsewhere in the system, for example, as a dimension:
With the Measurement dialog expanded, click and drag to highlight the value you want to copy:
- Before releasing the mouse button when highlighting, use keyboard shortcuts to copy the value
- OR after releasing the mouse button when highlighting, open the Measure dialog again (the value will still be highlighted) and use keyboard shortcuts to copy the value.
- For more detail kindly refer below link.
- https://cad.onshape.com/help/index.htm#measure-ps.htm?Highlight=part measure
5
It sometimes happen for a short time when something else in background is going on in the browser. Usually it may possibly happen when webpage is loading in another tab and geometry is clicked in active tab.0
5 -
The measurement popup showed up again this morning. So I guess you guys are correct.
Thanks for your input.0
