Convert .obj to .stl
Hello dear community,I would like to convert a .obj file to .stl. There is also a window that I have to select. Can you help me? I want to convert it and print it as it is without change in a 3d printer.
  • GWS50
    GWS50 Member Posts: 535 PRO
    Import the OBJ using the 'Single Part Studio' option, (right hand window)
    Right click on the mesh in the part studio and select export and then STL from the drop down menu.
    Alternatviely use Meshmixer or Meshlab, both free software. Open the OBJ in either and export as STL.
