Linear rails / carriages in assembly
graham_lock
graham_lock Member Posts: 276 PRO
Hi,
I have an assembly containing a linear rail / carriage pair, they are mated with a slider mate.
I want to add two of these sub assemblies into the main assembly, parallel to each other.
What do I need to do to make the carriages track each other?
Thank you.
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 984 PRO
    Accepted Answer
    A Planar mate would do it. Or a Fastened with an offset.
  • graham_lock
    Accepted Answer
    Thank you.
    I tried the fastened mates approach but that stopped either carriage from sliding?
    The planar mate works perfectly!
  • _anton
    _anton Member, Onshape Employees Posts: 550 image
    What would make them track each other in the physical assembly? Would there be, e.g., a gantry connecting the carriages? Fastening that to both would achieve the desired result. Alternately, planar mates.
  • Matt_Shields
    Accepted Answer
  • graham_lock
    Accepted Answer
    Thank you.
  • robert_scott_jr_
    robert_scott_jr_ Member Posts: 905 ✭✭✭
    Where did you place the fasten mates? - Scotty
  • graham_lock
    Hi,
    I placed them at one top corner of each of the carriages and at the bottom matching corners of the gantry profile.
  • _anton
    Perhaps you need to offset the mate connectors you're using for the fasten mates.
  • graham_lock
    Thank you - I’ll try that.
