Which endpoint supposed to perform export anotation request which corresponds to the schema.
Konst_ShKonst_Sh Member Posts: 137 PRO
edited September 2024 in Using Onshape
I can see this schema in onshape drawing json samples repo, which looks like a way to export drawing annotations separately from full drawing json export, which should run faster and I would prefer to use it:
https://github.com/onshape-public/onshapedrawingjson/blob/master/definitions/differentAPIs/request/exportannotationrequest.schema.json
Though can't find the endpoint which might use it in api explorer. Is it not exposed yet?
