Imported image not extruding correctly
An imported DXF image that I uploaded to onshape to make a stencil is not extruding correctly. Most of the image is extruding/removing correctly apart from one letter. If I try to extrude/remove the one letter it will cause an error, however if I do extrude/add then it works fine. Any ideas on how I could solve this?
I've added two images for clarity and the document is also public : vloonlogo
Any help would be greatly appreciated.
Howdy, Stranger!
