How to make a 45 Degree Bend in a Pipe?
Im trying to make a model of the frame of the go kart I want to make but I dont know how to make bends in the pipes. Can someone help me. Do I use a sweep or a loft also?
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,960 PRO
    Use sweep for this. Also you could use the Frame feature. Either way you will need to create planes and sketches and use the sketch lines as guides for either the sweep or the frame.
    Also check out the learning pathways, they are fantastic for learning Onshape:
  • MDesign
    edited October 2024
    Generally a sweep on a sketch is as simple as it gets but you might also want to check out the new routing curves and control curves. Interesting stuff.
    https://forum.onshape.com/discussion/24874/routing-curve-control-point-curve-introduction-of-two-new-features-for-3d-curve-creation#latest
