Sketch line become construction line no matter what
I'm working on the following assembly: https://cad.onshape.com/documents/8496c9b72e2d4e8b72e4f828/w/763de19ddd8ab93854b99ad2/e/4cdd894be664232ff91d5730?renderMode=0&uiState=670d403edc9f965d214805e3
I'm on the very last step where I am trying to hollow out the cone/tip. I created a line in the sketch "InteriorCutout" that is fully defined. However, when I confirm the sketch, it automatically converts to a construction line. Since it's a construction, I can't select it as an edge in the loft tool, which results in the loft tool selecting on of the vertices and going to that. What can be done to make that solid and thus select the edge?
I don't see anything about automatic conversion or conditions in the docs: https://cad.onshape.com/help/Content/sketch-tools-construction.htm?tocpath=Part%20Studios%7CSketch%20Tools%7C_____23
I've also tried forcefully going back to the sketch and toggling construction mode, but it always stays the same.
  • Oliver_Couch
    Oliver_Couch Member Posts: 230 ✭✭✭
    It's not a construction line - it shows as a broken line to indicate that the sketch element is behind something else.
