Aligned measurement issues
anthony_dean
anthony_dean Member Posts: 8 ✭✭
I am having trouble creating dimensions between points on a drawing that don’t align horizontally or vertically. This may be referred to as an Aligned measurement.
At the page:
https://cad.onshape.com/help/Content/drawings-dimensions.htm#PlaceText
it says: “Dragging the text around during preview allows for the text to move outside of the extension lines, and also switch between horizontal, vertical, and aligned measurement modes: Dragging the text away in a direction perpendicular to a line through the two chosen snap points creates a dimension line parallel to the two chosen snap points”
However, I find this rarely works. With the dimension tool active I click on two diagonal points and Onshape instantly wants to create a horizontal or vertical dimension between the points regardless of where I drag the dimension text. The pull-down options on the Dimension tool include one for 2 point linear dimension, however having this option active still results in the ability to make only horizontal or vertical dimensions. After several minutes of canceling and reactivating the Dimension tool I can sometimes get a point to point aligned dimension between two diagonal points - but this problem is very frustrating.
  • Oliver_Couch
    Oliver_Couch Member Posts: 230 ✭✭✭
    You need to drag it further away. Try zooming out.
    There's an improvement request logged to make drawing dimensions work the same as sketch dimensions.
  • Oliver_Couch
  • rick_randall
    rick_randall Member Posts: 439 ✭✭✭
    edited October 2024
    The point to point dimension tool "should" have a third selection pick, (pick a line, after picking the two points) that forces the dimension to "align" to that particular line, or other existing geometry.
  • anthony_dean
    Re: "drag it further away. Try zooming out." - Yes, this does work sometimes - Thank you.
    This is still a suboptimal tool for aligned dimensions, so I await the rumored improvement coming.
  • Lloyd_Snell
    Lloyd_Snell Member Posts: 36 PRO
    Wouldn't that be nice, a third selection process. Versus waving your mouse around trying to have it understand what you want.
