Any way to feed additional info into the Manipulator Change Function?
joshtargo
joshtargo Member Posts: 690 EDU
I want to use a Real from definition to adjust the sensitivity of the perceived manipulator movement.
any way to do this?
    S1mon Member Posts: 4,613 PRO
    Look at the code for Bridging curve and the older magnitude type (not control point) of manipulation. I’m pretty sure there’s a sensitivity multiplier in use there.
  • joshtargo
    edited October 2024
    it works ( i didn't use bridge code, but somehow it helped me find where to look)
