how do I set default viewing mode (shaded with edges)?
joshtargo
joshtargo Member Posts: 657 EDU
I seem to have to set it for every single model I look at
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,897 PRO
    Right click on "shaded with edges" and select "make default" (or whatever the exact wording is). Also you must have changed at some point as shaded with edges is the default setting
  • eric_pesty
  • joshtargo
    thank you for saving me
  • james_aguilar160
    james_aguilar160 Member Posts: 59 ✭✭
    If you right-click on the setting in the view menu, there it will pop up "set as default." This appears to apply at least to all tabs within a document, not sure about across documents but I recommend you give that a try.
