How do I select an area defined by multiple lines?
I'm trying to select the area defined by the two circles and two lines so I can extrude it. How would I do this? My ultimate goal is to make a gear.
there is a gear custom feature in case you don't want to reinvent the wheel. If you doing it for exercise, respect. The extrude feature should let you select that area among all the other closed in areas as well.
1 -
