Loft issue
I am trying to loft this 2 ellipses to make a turbine blade, however, the ellipse in the hub is always in construction line and doesnt click when i select it, what could be the problem? Below is an image and attaches is the link to the project. Thanks.
https://cad.onshape.com/documents/be862d4f9f062ba2ec96ae96/w/1b149e1919326c31cab5ee2a/e/14fae3aed09029f3cf1ad511?renderMode=0&uiState=6724eadddd827314aabeafb4
It's just hidden by the hub. use the select other function or the <`> key while hovering. or turn off the hub part visibility. looks like you got it done though.
Thank you very much, I used some other method on the constraints to work around it. Will use this now.
1
