Scaling tables (BOM)
spiritriderspiritrider Member, csevp Posts: 32 PRO
Is there a way to scale down or up a BOM table in a drawing? I would like to uniformly scale down my BOM to better fit my drawing and the assembly I am showing. Normally My BOM is on a separate page, but I wanted to put my BOM on the assembly, but scale it down a bit to not dominate the drawing. It might be available, not seeing a way to do so.
Thanks
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,501 PRO
    You'd have to change the font size first, then you should be able to drag the corner opposite the anchor point to resize.
