black back ground
This is the first time using this computer for onshape and i am getting a black background so i can't see anything black. did you change anything or is it me?
  • martin_kopplowmartin_kopplow Member Posts: 1,498 PRO
    Is maybe you browser set to use a dark mode?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 976 PRO
    In Onshape, a black screen indicates that you are having a graphics rendering problem (or you're in dark mode).  If you are in Chrome, check to make sure hardware acceleration is enabled:
    • Go to chrome://settings/
    • System
    • Make sure “use hardware acceleration when available” is checked.
    • Go to chrome://flags/
    • Make sure “Override software rendering list” is Enabled.
Howdy, Stranger!
