View options (camera options) for parts in Drawing
fabian_mühlberger066
Member Posts: 16 PRO
Hi,
Are there any camera and render options in drawings?
This is a mockup of a crate with multiple boxes in it. In the assembly, I can make some parts translucent, to show its content, but cannot create simple dimensions.
Creating a drawing does not help, since I cannot set the view (camera and render options) mode as in the assembly. As well as changing the opacity of one or more parts. In my case, the crate is then simply one box, which is fine for construction, but not for discussion with my colleges.
Ideally, the drawing should give me an option to change the view mode on one or more parts of the imported assembly. Allowing to set it to translucent, or unshaded with hidden edges visible. The best would be to color the edges of the parts differently to distinguish between them.
First image: simple assembly with translucent parts, but no option to dimension.
Second Image: Unshaded with hidden edges visible would be Ideal for the drawing, with colored part edges.
Help is appreciated!
Best,
Fabian
Not currently possible unfortunately…
I think it's similar to this request: https://forum.onshape.com/discussion/18913/isolate-in-drawings-and-or-mixed-rendering
Would the cadasio app available in the onshape store be useful for this?
