Sheet metal flange using featurescript
guillauem_d
guillauem_d Member Posts: 20 ✭✭
Hi everyone! 😁
I'm working on creating a very basic flange on a square flat sheet metal part using FeatureScript. My goal is to eventually generate a 90° flange by selecting the edge of the sheet.
I managed to achieve it by copy-pasting the entire code from the official standard library, but I’d like to know how to simply call the function export const sheetMetalFlange = defineSheetMetalFeature(function(context is Context, id is Id, definition is map) in my own project without having to duplicate all the code.
Any guidance on how to do this would be greatly appreciated! 😀"
  • Caden_Armstrong
    You don't need to copy all the code, you can just import it:
    import(path : "onshape/std/sheetMetalFlange.fs", version : "2506.0");
  • guillauem_d
    Thank you for your answer, Caden! 😊 I was aware of the import method and had tried it, but I still couldn’t manage to get my preconditions working properly.
    Eventually, I found that using export import when importing the code resolved the errors and fixed the issue!
    Thanks again for pointing me in the right direction! 👍
