Error: "Should be unreachable!"
Axel_Kollmenter
Axel_Kollmenter Member, pcbaevp Posts: 437 PRO
Hello everyone,
I got the custom Featurescript "Form Sheetmetal" from @MBartlett21. We are using this on a daily Base to add embossing feet etc. Now I got a problem I´ve never seen. It says "Should be unreachable"… It worked the first time, but the error message appears with the second feature.
Does anyone had the same message before and could help?
Thanks!
Best regards,
Axel Kollmenter
  • MBartlett21
    @Axel_Kollmenter
    It looks like you are using an older version, possible not from the original document. That error message is now a warning that you haven't selected a sheet metal part.
    This could be to do with 'recent' changes to how Onshape's sheet metal works internally (i.e. the new corner break stuff, holes, etc.).
    IR for AS/NZS 1100
