Gridfinity generator with bins that fit filler base space
I found this pretty awesome Gridfinity Generator https://cad.onshape.com/documents/f307f8af01083b99b55bbcf9/w/e62d7ab7a660a796bb9461a7/e/6f4023e4bb25eda38c5e4f2d and found that adding filler to the base will add a new section for a bin to be slotted in. I am wondering if it's possible to use this generator to also create bins that can fill in that extra space? I have a drawer that is 24mm shy of perfectly fitting the standard 42mm gridfinity base. The base generator will generate a new slot that is 24mm when I use the fill settings but I am not seeing a way to update the bin to slot into this 24mm filler section.
