How to quickly produce multi part arrays?
My goal is to design a part, say rectangle for ease of explanations, i want it to be, x,y,z 20, 30, 10-12mm. How can i design one rectangle then have onshape produce say 10 more rectangles ranging from 10 to 12 mm. Would make 3d printing test parts much easier and faster.
Thanks for all your help guys
I think you're looking for configurations.
You can do it fairly easily with variables and patterns. It takes a bit to get used to it at first but not bad once you get the hang of it.
https://cad.onshape.com/documents/a033e52f5f46d93f062fd9e5/w/767c6ea70061bc8ccf170709/e/126ab9927e01e46a1598ef21Here's a detailed discussion of this and more:
And if you need more control you can use variable arrays as well as discussed in "part 2":1
