Exporting to dwg/dxf question
nuno_castro
nuno_castro Member Posts: 2 ✭
edited July 2016 in Community Support
Hi,
It is possible to export the sketches to dwg or dxf format with quotes?
Regards,
NC
  • jakeramsley
    jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 669 image
    Hi,
    Regards,
    NC
    Can you clarify what you mean by quotes?  We do allow exporting of sketches in dxf/dwg formats.  If you right click on the sketch in the feature list, there should be an option 'Export as DXF/DWG'.
    Jake Ramsley
  • nuno_castro
    Hi jakeramsley,
    I mean export the sketch in dwg but with all anottations and references.
    See attached image.
    Regards,
    NC
