How to keep the width of a loft constant.
ahmad_arab
ahmad_arab Member Posts: 4 EDU
I create a loft between 2 identical squares the loft ends up becoming thinner and doesn't maintain a constant width, is there a way i can fix this?
  • EvanReese
    EvanReese Member, Mentor Posts: 3,095 PRO
    I think this is just a geometric issue. If your angle formed a 45° it would be equal, but the more it doesn't the sharper it gets like this. Could you just draw the shape you want from the side view and use Extrude instead?
