How can I lengthen the fillet?
j_t290
j_t290 Member Posts: 2 ✭
first of all my phttps://cad.onshape.com/documents/f6bcc3119cd471311366c79c/w/6ad515d3f4877077744c54a4/e/1054ed4e78784073109f3c77?renderMode=0&uiState=675c86eba4292b36f888de53rojekt:
Hi I am new to oneshape, I want to creat a fillet, that has a heigth of 5 mm. The problem is that I can't just set the radius to 5mm, because Cylinder is to small and long for that. So how can I creat a fillet that goes 5mm up?
I hope you understood my question:-)
  • eric_pesty
    Your cylinder is 7mm diameter so you can't put a fillet more than 3.5mm without creating a sharp point. I'm guessing you want the tip to start curving 5mm from the end…
    Two options I can think off depending what you are trying to do…
    • You could try using the asymmetrical option in the fillet tool to go 5mm one way and 3 the other way.
    • Sketch the shape you want and revolve to remove material.
