Shell entire object, not just one section
I'm trying to create a bottle but I'm not able to shell the entire object, it's only shelling the second extrusion where the threads will go. Anyone know how to make it shell the entire bottle?
  • jelte_steur_info
    I don't see the issue. just select more faces to shell more bodies.
    hit ~ on your keyboard for 'select other'dialogue
    If there's an error occuring, please make your part public so we can help and specify what you've tried and want to accomplish more clearly.
    in the screenshot, nothing is selected in the Shell 3 feature, so… what's the challenge?
  • BenTaylor
    BenTaylor Member Posts: 51 PRO
    I believe it is only shelling the threaded section because it is a distinct body. If you boolean the two together (or use "Add" instead of "New" on your extrusions), then the shell will be applied to the entire part.
    Ben Taylor
    Lead Mechanical Engineer @ Healing Innovations
