How do I constrain all sides. When I try I get "Sketch could not be solved"
When I try to constrain this part in my sketch it shows everything in red. But i've been told everything must be constrained for best practice. I cannot figure out how to do that.
https://cad.onshape.com/documents/65c38a89baa84a58979f07f7/w/25c04dfe872071e687af3c5c/e/bedc43603808e12a1e80c387?renderMode=0&uiState=6766216f83379a6e644fd539
That 37 is unnecessary because the whole thing is 145 and you've got other horizontal dimensions (5, 83, 10, 10). What's missing is the height of that right rectangle.
3
3 -
The length dimension (37) is already implied by the other dimensions (145-5-10-10-83 = 37) so you cannot add a driving dimension without overconstraining it all and making it go red. What you do need is some sort of dimension for the vertical spacing of those 2 blue entities. Or otherwise add a constraint to make them align vertically with the 83mm long line segment. Add one such thing and the whole sketch will be fully defined,
3
