Blend Faces
michael_richter
michael_richter OS Professional Posts: 3
edited July 2016 in Community Support
I'm currently working on a boat hull project.
As I did not manage to create the hull using one loft from stern to bow, I tried to model the bow section as a separate part.
The face of the bow needs to be curvature continuous to the rest of the hull geometry.
Unfortunately I can not find a good solution by creating lofts neither horizontal nor vertical.
What would be a good approach to blend faces the way I need it?
  • michael_richter
    In Moi3D it is possible to create a loft that ends in a point or line, as far as I can see this is not possible in onshape (yet)?
  • jakeramsley
    jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 669 image
    You can do a solid part loft to a point.  You can do a surface loft to a point or a line.
    Jake Ramsley
  • michael_richter
    Thank you, the solid part loft to a point works perfekt.
This discussion has been closed.
