I want to split a A1 template into 2 A3 and 4 A4 templates
Hello for a project i need to split the A1 drawing sheet into the sections mentioned above but when i try to place the lines which should outline these sections I cant edit them. Is there any way to make these lines or A3/4 templates?
  • martin_kopplow
    martin_kopplow Member Posts: 1,627 PRO
    While I think it should be possible, I think it takes a lot of effort that could better be spent elsewhere: Why not use a PDF editor app to assemble the A1 sheet from the two A3 and four A4 drwaings after the fact?
  • MDesign
    MDesign Member Posts: 1,466 PRO
    if you have access to another CAD program like AutoCAD or similar it's probably easier to design title blocks in there and import to onshape
    S1mon Member Posts: 4,564 PRO
    You can also just use sketches in a part studio in Onshape.
