Threaded Holes made with Hole feature called out for "Up to Next" in drawings
I'd like to callout a hole made as shown above where the tapped hole is made through one wall. Typically I'm used to calling this out as "UP TO NEXT" or "THRU 1 WALL" as the depth is a virtual and non-inspectable dimension. Is there any way to edit the hole callout to show as such in the drawing without manually typing out that content? (I'd like it to stay linked directly to the parametric feature).
  • glen_dewsbury
    glen_dewsbury Member Posts: 1,379 PRO
    This is what I get from the hole call out when using up to next in the part studio.
  • corlando
    corlando Member Posts: 2 ✭
    I agree, this is a miss in OnShape. A hole that pierces the material wall, even just 1 wall, therefore is not a blind hole = thru-hole. 99.9% of machinists out there would interpret this way. There is a difference between "thru" and "thru-all", again common-language for machinists. I submitted a support req ticket today on this topic + up-voted the comments above. A hole w/ up-to-next termination should = "thru" on the 2D print.
  • Alan_Guthrie
    Alan_Guthrie Member Posts: 9 ✭
    +1. Ideally if there are multiple 'to next' holes with the same thread/dia but different target depths, it should still be able to automatically count all of them per face/view and list them in a single callout.
