Tapered external thread simplified drawing view?
EvanReese
EvanReese Member, Mentor Posts: 3,095 PRO
The hole attributes assigned to tapped holes and external threads signal the drawings to render a simplified thread representation. There are Tapered Pipe Tap holes in the Hole feature which look like this. Left is actual model geometry, and right is how it shows up in drawings. Is there a way to do the equivalent for external threads (tapered, not straight)? I see that in the holeAttributes for external threads there's one called "isTaperedPipeTapHole", but setting it to true doesn't do anything to this view.
