How to make an AR-15 rifle barrel
jay_williams
Member Posts: 21 ✭
An AR-15 rifle barrel has varying diameters along its length. It also has a taper from the chamber near one end down to a smaller diameter a few inches away from that end. If you aren't familiar with this, just google "AR-15 rifle barrel" and you'll find some pictures to see what I'm describing.
I've created a single tube, of 1" diameter with a .223" bore. That was pretty easy. How do I specify the diameters of specific sections of the tube? Also, how do I create the taper near the chamber end of the barrel? I would like to be able to play with these diameters and the lengths of these diameters. Is that easy to do, or once I create a specific section of certain diameter, am I stuck with it? I tried this with SketchUp and there was virtually no flexibility to change lengths of varying diameters.
Thanks,
Jay
Thanks,
Jay
Check out the tutorials on the revolve feature.2
Will do. Thanks.coleman said:Check out the tutorials on the revolve feature.0 -
Some of the techniques to demonstrate variable diameter helices and sweeps can be found in this public document:-
https://cad.onshape.com/documents/a0acd75a9d0d4a1a751f642f/w/1dd2693a236bb7d21dda7908/e/ede20c1d949b257f72bc4b7b
Philip Thomas - Onshape0 -
Great! Thanks!philip_thomas said:Some of the techniques to demonstrate variable diameter helices and sweeps can be found in this public document:-0
