Linking Objects
dylan_ball058
Member Posts: 2 ✭
How would i go about linking these two together using a tube? For example, point A to point B.
Hi @dylan_ball058,
Try these things:- Share a (public) document so people can have a closer look to help out
- Create a sketch that connects point A to point B
- Sketch a profil for your tube that you want to use to connect the two points
- Use the Sweep command to create the tube along the path
1 -
I would just add that if the circles you are trying to connect are different sizes, you will need to use a loft with a path method.
1
