opSplitFace with text
ben_partouch
ben_partouch Member, csevp Posts: 168 PRO
edited February 2025 in FeatureScript
Hi,
When trying to split a face with the text sketch region, the feature picks up the construction lines created by the text feature and uses them for the split op as well. Why is that? I thought construction lines are not considered fully inclosed.
How do I fix it?
Thank you.
  • ben_partouch
    solved :)
        var textEdges = qSketchRegion(id + "sketch2");
        var loop = qLoopEdges(textEdges);
