How to remove cross lines from drawing?
andrew0221
Member Posts: 2 ✭
I have a design I am going to cut out with a laser cutter, so I export it to a drawing so that I can export it as an SVG file. Problem is, when I try to insert the object into the drawing, it has cross lines that aren't removable and are included in the SVG file.
right-click the view. show/hide. hide auto centermarks.
1 -
Or right click on the face of the part in the Part Studio and select "Export as DXF", assuming that your laser cutter can read DXF files.
