NOOB at work... very basic question
Hi all. Hope you're having as much fun as I am here.
Got a starter question so sorry if this has been covered a billiion times.
Am trying to draw a shape whose name I don't know but it has uneven sides. When I do dimensions for a rectangle, if i do dimensions on one side, its automatically mirrored to the opposite side… HOW do I trun off that mirroring?
I told you it was a basic noob question… but if anyone has the copassion to help a beginner out that;d be sweet.
THansk all
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 988 PRO
    Either check the "show constraints" checkbox and delete the parallel and perpendicular constraints or don't use the rectangle tool. Use the line tool to draw an irregular polygon.
  • MDesign
    MDesign Member Posts: 1,466 PRO
    quadrilateral? check off the show constraints and remove the constraints that are causing the issue. also check out learn.onshape.com to learn more about constraints and more
