Help with creating a drilling guide
I'd like to 3D print a couple of drilling guides for the 2x1 and 1x1 MAX tubing we are using to build a robot. This tubing has holes in a grid pattern. I have drawings of the tubing from Revrobotics.com in Onshape. Based on some of the tutorials I've done here, I think I should be able to use/project the hole pattern from the tubing drawing onto the sketch of my drill guide, but I can't even figure out how to get the tubing drawing into the document containing my drill guide sketch. Total newbie here so thanks in advance for your patience!
  • eric_pesty
    You can either use a "derive" feature in your part studio to bring your reference part in (probably the best option), or you can create your part studio "in context" from your assembly.
  • cullen_pendleton
    cullen_pendleton Member Posts: 4 EDU
    Thanks Eric. I will give that a try.
