What is the quickest way to create a plane at the middle of a part?
florian_ford
florian_ford Member Posts: 54 ✭✭
edited July 2016 in Community Support
I have a long tube and another item at one of its end which i want to mirror on the other side (imagine a plane normal to the tube as the mirror plane).
What is the quickest (best practices) way of achieving this? Say my end faces of the tube are hidden and i want to somehow just create a plane on one face (it creates it by default at midpoint) and flip it 90 degrees. This doesn't seem possible in OS.
  • florian_ford
    edited February 2016
    Ok, sorry to post my own answer but I might have found the way to do this. I somehow missed this before.
    So if I select an edge and hit create place and choose the Mid Plane it should create a Plane Normal to that Edge, which is exactly what I need.
    If I knew how to create GIFs I would post this maybe others will benefit too, but for now i hope the text explanation will suffice.
    I'll mark this as the answer to stop diverting you guys from more important answers. Edit: Hmm, can't mark my own comment as an answer...
  • viru
    @florian_ford , You have to select both end face of tube and after that select plane option. it automatically create plane in center of tube. Kindly refer below video for more detail.
  • florian_ford
    Thanks for the effort.
