relict
have you tried this sequence of operations manually?
does the extrude work? (debug the extruded bodies and comment out the boolean for testeing)perhaps there's something with the extrude (e.g. up to next) that's not compatible with sheet metal…
can you share your document for more in context help?
Hi,
yes, when commenting out the boolean operation, the script works fine. I have used this booleanBodies operation in another Featurescript which where it works accordingly on sheet metal parts and normal parts.0 -
I cannot access this document since i'm not signed in to advancedengineering.onshape.com but to cad.onshape.com. did you make it public?
(is this custom domain for enterprise users? haven't seen it before)
