Error with extrude on point selection
Matthew380
Matthew380 Member Posts: 50 ✭✭
So I just started feature script and was going through the lessons, however when I tried to do create a extrude on a sketch that I made on a point it failed
However when I remove the extrude I can see the sketch so why doesn't this work?
Here is the doc https://cad.onshape.com/documents/b2796104b9b0304547a8abee/w/fdfe0d0c32d8a9d9c0db7fc5/e/dc41644a1289cee5a798bf87
  • Matthew380
    Never mind, I figured it out You need to multiply the normal in the plane
  • jonah_baird
    jonah_baird Member Posts: 4 ✭
    I dont know how to use feature script, sorry :(
  • Matthew380
