Plane at line angle - angle changes
graham_lock
graham_lock Member Posts: 277 PRO
Hi,
I have a plane at line angle where the plane angle changes depending on the angle of the line it is referenced to.
I'm sure it's something I'm misunderstanding.
An example is below:
Any help appreciated.
Thank you.
  • MichaelPascoe
    This way of making a plane can be unpredictable like you have found. Try using a mate connector instead. You can fully define the primary and secondary axis direction.
  • MichaelPascoe
  • graham_lock
    Thank you, I'll try that.
