I am looking for help
avery_johnson708
Member Posts: 2 EDU
I want to put raised text on the outside of a cylinder (coffee cup). I am not real good at CAD but I get by.
U want to try to use the Wrap tool to ur advantage like this
Creat text on the clinder (Most likely will be on a plane)
Then use the wrap tool to help you like this to add the surface you want
Here is the doc to see exactly what I did: PS U can use the angle to make it not look upside down
1 -
Try the too: https://www.youtube.com/playlist?list=PLfl1MlLvzE_o6emduIhP-0IocQWubmW6F
