frame generator
Farra
Farra Member Posts: 11 PRO
Is there a a way to group tubes that are all the same instead of having each one as a separte part even if you have 6 others exactly the same size.
  • David_YL_Nguyen
    David_YL_Nguyen Member, Onshape Employees Posts: 184 image
    Hey @martin_farrow,
    What exactly do you mean by "group" them? Did you try the cutlist feature to finish your frame profiles?
    You should then get a composite part for the whole frame/weldment + a cutlist with the exact quantity + lengths of unique profiles.
