Cookie Stamp Curved and INVERTED OR FLIPPED Text
Hello,
I can model a rubber stamp :) And I know how to create curved text :)
However, in 3D modeling a cookie stamp for our school, I am not able to flip and curve the text in the Surface Text Feature. I can only change the text direction and align it - neither of which gets me to where I need to be when stamping into dough.
Thoughts? Thank you!
  • David_YL_Nguyen
    David_YL_Nguyen Member, Onshape Employees Posts: 184 image
    Hey @Amy_Sarofian,
    Could you please share a link to your public document, so people can have a look to help.
    Short answer is probably just to change the view/orientation of the plane/surface that you put the text on. Will probably be easier to show an example.
    Thanks
  • Amy_Sarofian
    Amy_Sarofian Member Posts: 5 ✭
    Yes! Thank you. Here is the link. The bottom view is the intended outcome.
    https://cad.onshape.com/documents/1b24eb68953d5e1099ce915f/w/dc4119cd855b87608f96196e/e/785048bbc7653e6d746e91b6
  • jnewth
    Hi @Amy_Sarofian
    I made a custom feature to simplify tasks like this. It tries to make the usual stuff (arranging, flipping, orienting, rotating) text a bit simpler. It may help:
    Try it out if you can't get Surface Text to work. Read about "Text" here: https://forum.onshape.com/discussion/comment/101768
  • jnewth
    @Amy_Sarofian A simpler way to do this occurred to me: Model the 'cookie' and not the punch. Then create the punch that forms the cookie by taking a blank stamp (so, any solid like a cylinder or a rectangle), and then boolean subtract the cookie part from the blank stamp part. The resulting stamp part should be the stamp that would make the cookie.
  • MDesign
    or just put the sketch on the outer face of the punch and set the extrude parameters for accordingly.
  • kate_leipold_rit
    kate_leipold_rit Member Posts: 43 EDU
    I like your cookie cutter! What a fun idea!
  • jerry_gen
    jerry_gen Member Posts: 2 ✭
    amazing idea
