Basket
can anyone help me? I'd like to build this chip tray for a project
Your approach will vary a lot based on your specific needs:
- How accurately you want to represent it.
Do you need to model the wire
Is just the general idea of "walls with tons of squares punched out" enough? - Is it being modeled for output/printing?
If you go through the onshape tutorial "Onshape fundamentals" you should be able to make a simple version of this: https://learn.onshape.com/learning-paths/onshape-fundamentals
0 - How accurately you want to represent it.
Need to know how you are going to build it — what kind of tools and materials are available to you? — and what level of resources are you willing to dedicate to the task?
- Will you be wrapping support wire and welded mesh around a form, and brazing or spot-welding?
- Do you have access to a spot welder?
- 3D printing it (will be very weak, unless e.g. you print the sides flat then join them)?
- Using individual wires (would take forever)?
- Thin plywood and a laser cutter?
The specific product in the picture you attached is in the '$500k..$1M to build a semi-automated production line, then $0.35 each' category.
0 - Will you be wrapping support wire and welded mesh around a form, and brazing or spot-welding?
OK, . . . I just had to model it for fun.
—Eldonb
https://cad.onshape.com/documents/7e30168f7b26e3335939e859/w/16bfd4d58bb20ab5261bdbec/e/9ba72fe336ad37f71f15c4e0?renderMode=0&uiState=682ad02c84e522147fd39b95
