Does Onshape have this spline fit feature?
bast_industries
bast_industries Member Posts: 4 ✭
hello does onshape have this spline for feature shown in the video below? I have imported a sketch but I want to smooth out all the spline curves to one curve and arcs and circles.
https://youtube.com/shorts/ge2TU6z0X6M?si=YgTZF4dwfLLk2wuA
Best regards,
Bast
  • jelte_steur_info
    If you only want to combine them into one, without editing anything, use 'Composite curve'.
    if you really want to smooth it out, try 'edit curve'.
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,930 PRO
    The function isn't the sketch but the "edit curve" feature with the "approximate" option can basically do this. Although you will end up with a "curve" entity instead of a sketch
  • EvanReese
    The other suggestions here are good, but the 3D Fit Spline feature with Edges mode is the closest thing to this, though as others say, it won't be sketch curves anymore. You could create all of your fit splines, then make one final sketch and "Use" the new splines to get it all back into one sketch again.
  • bast_industries
    Thank you I will try these and see how it works out this week
