Rotating a sketch rectangle
graham_lock
graham_lock Member Posts: 277 PRO
Hi,
I'm drawing a rectangle which I want to rotate:
I have a rotation transform matrix where the angle is user driven:
var rotationMatrixStart = [[cos(definition.freeXYStartRotation), -sin(definition.freeXYStartRotation)], [sin(definition.freeXYStartRotation), cos(definition.freeXYStartRotation)]] as Matrix;
And a sketch:
skPolyline(sketchStartFormer, "profileStartFormer", {
"points" : [
startProfileCorner1,
startProfileCorner2,
startProfileCorner3,
startProfileCorner4,
startProfileCorner1
How should I go about rotating the rectangle about its centre point to achieve the equivalent of:
If I apply the rotation to the points before sketching them then the rectangle rotates about the centre of the sketch plane.
Any help appreciated.
Thank you.
  • Alex_Kempen
    Alex_Kempen Member Posts: 258 EDU
    Your "partQuery" is for solid parts (qBodyType with BodyType.SOLID), which you won't have in your part studio. qEverything(EntityType.BODY) should be sufficient for deriving a sketch.
  • chadstoltzfus
    chadstoltzfus Member, Developers, csevp Posts: 175 PRO
    Sorry, forgot that I extruded something in the Sketch Config part studio, so pretty much the instantiator is bringing in the extrude part and booleaning it. But you can more or less use the same technique to import a sketch. If you comment out the opBoolean() in your document you should see that the sketch has been brought over successfully.
    chadstoltzfus@premiercb.com
  • Alex_Kempen
    edited June 2025 Answer ✓
    In FeatureScript, a Plane is simply a map with an origin, x, and normal. If you have a Plane you're using to create a sketch in one orientation, and you want a Plane in a different orientation, you can just use the plane constructor to make that plane directly from your existing plane, e.g., const newPlane = plane(oldPlane.origin, yAxis(oldPlane), oldPlane.normal);
  • glen_dewsbury
    glen_dewsbury Member Posts: 1,378 PRO
    edited May 2025
    removed
  • graham_lock
    Thank you but I need to do this in Feature Script.
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 1,002 PRO
    Does this help?
    https://cad.onshape.com/documents/164c09de99073544524150c2/w/95e2fe023391a43f159891ac/e/af7550ab2e2d704f6e3c7c38
  • graham_lock
    Thank you.
    So if I'm understanding this correctly, when using Sketcher it's possible to transform around the centre of a sketched area, but in Feature Script there is no such transform available so the sketch plane centre needs to be at the centre of rotation of the area to rotate?
  • chadstoltzfus
    There isn't anything like a skTransform function (at least not one that's publically documented). When making sketches in FS, it's more important that you get your initial coordinate system correct, instead of creating a sketch somewhere and then moving it. That's part of the reason that the sketch documentation says constraints are mostly unnecessary when sketching in FS, you can usually pinpoint exactly where you want it with some good vector math. Another approach could be to sketch and extrude, then do the opTransform function (this depends on the use case of course).
    If you want my advice though, I would recommend staying away from sketching in FS. What I do almost every time I need sketches generated by a custom feature is I make a part studio with that sketch in it, set it up with configuration parameters, then I just derive the sketch in using the custom feature and from there it's much easier to place/rotate the sketch entity. It's also way easier to edit that sketch since you can just edit it in a part studio instead of redoing your logic for constraints in FS.
  • graham_lock
    Thank you.
    How do you derive the sketch into a custom feature and then set the configuration parameters?
    in my use case the final part is a loft between two sketch profiles. The user selects the profiles shapes / sizes, x/y offsets and rotation in the feature UI.
    Would that be possible with your recommendation?
    Thanks again.
  • Matt_Shields
    It's been a while since I've taken linear algebra, but I think you can rotate about an arbitrary point. Translate → Rotate → Translate back.
  • graham_lock
    Interesting thank you.
  • chadstoltzfus
    edited May 2025
    Here's a really simple example. It was made for a different post on this forum but I commented the code you'd be using to import sketches. You're pretty much just using the instantiate function, there's plenty of documentation on that here.
    https://cad.onshape.com/documents/cec79d6de564717d83526a2b/w/6552169cf2769c6c4135d9f1/e/3a971c226d00e7eb7c24e3bd
    This is a pretty widely applicable technique. Pretty much any time you need a sketch you can do this instead. This also works just fine with imported parts as well, so there are times where I don't want to make complex geometry in a custom feature so I'll do the same thing and just configure a part and import that in using the same technique.
  • graham_lock
    Thank you.
    I've tried to recreate this document since it is read only but I get:
    IMPORT_DERIVED_NO_PARTS
    My test document is here:
    https://cad.onshape.com/documents/4dea6a14a5bba4a6744c3fe9/w/5d36b22c3c19762fd239743b/e/ba32108e071585a347d97118
  • Alex_Kempen
  • graham_lock
    Thank you, this gets past the derived parts error but then the boolean fails with:
    BOOLEAN_INPUTS_NOT_SOLID
  • Matt_Shields
    I don't think you can boolean a sketch and a solid.
  • graham_lock
    Thank you. Yes, I'm confused as the document which @chadstoltzfus linked to above appears to work.
  • chadstoltzfus
  • graham_lock
    Ok thank you- I’ll have a play.
  • graham_lock
    So I've now had a look at this and I'm having a problem with the orientation of my sketches:
    Red marks the planes where the sketches should be drawn, green marks where they are actually drawn.
    I've generated a test document here:
    https://cad.onshape.com/documents/0338be9cd81d93b51df4ed40/w/266f4f29d7de89b2f31933c3/e/c55a1ee535ec417f486604c9
    Ant help appreciated.
    Thank you.
  • Alex_Kempen
