feature script code from view code
I have a design and i use this to get its features:
feature_url = '/api/partstudios/d/' + did + '/w/' + wid + '/e/' + eid + '/features'
feature_response = self._api.request('get', feature_url)
the problem is in the revolve feature this is the only information i get about the axis
{u'message': {u'hasUserCode': False | |
u'nodeId': u'31IcQ62NC2iMQ1x/' | |
u'parameterId': u'axis' | |
u'queries': [{u'message': {u'geometryIds': [u'JFB'] | |
u'nodeId': u'FjCDPQl76cEw8kI'} | |
u'type': 138 | |
u'typeName': u'BTMIndividualQuery'}]} | |
u'type': 148 | |
u'typeName': u'BTMParameterQueryList'} |
i get the geometry id is JFB,
but when i check the sketch feature i find no entity with that id
so when look in the view code section from the viewer i find this:
var gqjatkDKRfynOL_query;
gqjatkDKRfynOL_query=qCompressed(1.0,"%B5$QueryM5Sa$entityTypeBa$EntityTypeS4$EDGESb$historyTypeS8$CREATIONSb$operationIdB2$IdA1S11.6$FXjvWm5Hqp3D6Ak_1wireOpS9$queryTypeSd$SKETCH_ENTITYSe$sketchEntityIdSc$miD53jbgEup3",id);
var lBQgwXAEEjDTse_query;
lBQgwXAEEjDTse_query=qCompressed(1.0,"&1bf$eJx1kMtugzAQRX/G3VY807AE4xAn4WW7asgGGbDAbQIUSCL69YUgdVNlOTNn7tw7L44J4qvoRt+kqgYK2fNLJssrH2RTu3zgtupr/ydsbAVVdRAS7OHAPqQuilDgogAm1AJNJ0tZ83NvG1CZhDkQ9SCHcd5yOEB/BTUAcj1EM1DJfmi6pbkGkCCb4TCYBk0rusdJXDgawIWtUlV9XYFNCT+PpbPrdcEp71LlLjsRttP17znOQ6gAdI8Y3KYoYJglVID+Swx5tRjABc0Bzc+a8rPz/CODs1diEJOsyBtZE04ykpMZwlqw6Q/vjm4l9VNIP1X3eDtu7WifP4WYElvV6HFiuhEx4Gp6gBO6ycLBbAlngY3J3N0FGZl/OTXxLVWalohbc74Jkk3fpB8oYum8+Asz0ZBN",id);
annotation { "Feature Name" : "Revolve 2" }
revolve(context, id + "FOnX1poAa6gstog_1", { "bodyType" : ToolBodyType.SOLID, "operationType" : NewBodyOperationType.REMOVE, "surfaceOperationType" : NewSurfaceOperationType.NEW, "entities" : qUnion([sGbPJfegkyLLsb_query]), "surfaceEntities" : qUnion([]), "axis" : qUnion([gqjatkDKRfynOL_query]), "revolveType" : RevolveType.FULL, "oppositeDirection" : true, "angle" : { 'value' : try(30 * degree), 'expression' : "30 deg" }.value, "angleBack" : { 'value' : try(330 * degree), 'expression' : "330 deg" }.value, "defaultScope" : false, "booleanScope" : qUnion([lBQgwXAEEjDTse_query]), "defaultSurfaceScope" : true, "booleanSurfaceScope" : qUnion([]), "asVersion" : FeatureScriptVersionNumber.V1675_VERSION_BUMP_FOR_COMPUTED_PROPERTIES_DOC });
from this we can extract that the entity id is miD53jbgEup3
is there anyway we could get this information via the api?
is there anywat we could get the same featurescript from the viewer from the api?
thanks
