Kiri tabs
don_b
don_b Member Posts: 169 ✭✭
seems like Onshape only allows one tab Kiri …..If I create a new document and derive a different part to program the Kiri tab from another document pops up when I add application Kiri tab to the new document… is this correct?….can I only program one part at a time in Onshape…..also I save a .kmz file but do not see how to load it into Onshape.
  • don_b
    I figured out that I can open Kiri with and use the .kmz file at
    https://grid.space/kiri/
    perhaps I also have figured out how to program many different parts and save the files as .kmz using the above link
  • don_b
